2002 xk8 trunk lock-out
Old Dec 9, 2019 | 02:52 PM
playmesa's Avatar
Default 2002 xk8 trunk lock-out
2002 xk8 trunk lock-out, but the kicker is the battery is OUT of the vehicle. I have taken the back seat out , but no access to trunk. Help!!
Old Dec 9, 2019 | 03:33 PM
MikeAlford's Avatar
Put the key in the boot opening slot next to the XK8 sign at the rear. Should open the boot.
Old Dec 9, 2019 | 04:06 PM
JayJagJay's Avatar
Yup!
Old Dec 9, 2019 | 10:25 PM
DavidYau's Avatar
Default If that doesn’t work, check out Nickjag7 post
If you don’t have a master key to open the trunk, check out other options in Nickjag7’s recent thread. Link below.
https://www.jaguarforums.com/forum/x...-trunk-226230/
Good luck.
BTW, this is a more than common problem. Our cars are often put in storage and the battery dies. Keys get lost. So some members have created inventive ways to dangle an emergency pull wire under the car to open the trunk
Old Dec 10, 2019 | 02:40 AM
Welcome to the forums playmesa,
That's taking the challenge to a new level!
With the battery OUT the vehicle, you can't use the method of powering from another battery connected to the engine bay terminals to energise the circuit as it is incomplete. The only solution is the keyway in the luggage compartment lid which is a direct mechanical link to the lock.
You don't mention Coupe or Convertible but the locking mechanism is the same and neither have access from the passenger compartment through the rear firewall to the luggage compartment.
The Lock (item 1) is normally opened by the electrical Actuator (item 3) pulling the Cable (item 2). The alternative of the keyway is physically rotating the Lock Barrel (item 4) pull the second Cable (item 5) to open the Lock (item 1).
If the Lock Barrel is seized and cannot be rotated, a more destructive method would have to be considered.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Dec 10, 2019 | 04:57 AM
Old Dec 10, 2019 | 05:21 AM
frankc's Avatar
Lets hope he has kept the rear boot/trunk key hole lubricated.
A 'Frank Tip' when ever I am disconnecting or removing the battery I get a towel. Double it over. Put it between the lock and the lid of the boot/trunk. Do it out of habit and it avoids these situations. I have also used the battery cover but that is more obvious to passers by that the trunk is open.
Old Dec 10, 2019 | 07:52 AM
Diddion's Avatar
What a good idea.
Old Dec 10, 2019 | 07:54 AM
Jon89's Avatar
I also place an old towel over the lower latch area. Well worth the effort in case the trunk lid decides to close on its own.
Old Dec 10, 2019 | 08:45 AM
bladerunner919's Avatar
I'm not sure I agree with that. The addition of a power source under the bonnet completes the circuit again, so should work fine.
Old Dec 10, 2019 | 08:54 AM
But you have the potential of creating a short if the +ve terminal is touching the chassis or the -ve terminal.
Old Dec 10, 2019 | 08:57 AM
JayJagJay's Avatar
This is true... ^^^^
If one can get under the bonnet.
They are not hard cars to break into when push comes to shove, anyways. Especially the convertible cars...
Old Dec 10, 2019 | 09:51 AM
Indeed, but that could be easily checked by testing for continuity between the -ve and +ve terminals under the bonnet. If there is no continuity, there is no short.
Old Dec 10, 2019 | 09:58 AM
Absolutely, the key is the best solution though.
Old Dec 10, 2019 | 09:59 AM
JayJagJay's Avatar
Well said! Good idea. I'm terrible with electrical stuff...
Old Dec 11, 2019 | 05:04 AM
frankc's Avatar
I think sometimes we could all do with the benefit of hindsight.
I tried the key in the key hole in the boot/trunk and the darn thing would not turn. So I decided to fix it. Take a look at this topic, it even has a pretty video to watch Click me to jump to topic
Hope it helps someone.
Old Jan 7, 2020 | 01:15 AM
wcben's Avatar
I've posted this in similar threads, if the car is a coupe with the "premium" sound system, pull the subwoofer, you'll have full access to the trunk.
bcclew
Jan 17, 2020 02:58 AM
slidefighter
Apr 29, 2018 07:14 PM
kladdkaka
XE ( X760 )
Sep 1, 2017 03:30 PM
Chris Ryan
Oct 26, 2012 10:43 AM
TonyW
Jul 6, 2009 06:15 PM
