Auto Trans filler hole location
Old May 25, 2021 | 07:34 AM
Pistnbroke's Avatar
Default Auto Trans filler hole location
1997 XK8 Watched the videos...found on RHS TWO plugs with hex drive ...Which is it or is it either.
Thanks in advance
Old May 25, 2021 | 08:53 AM
JayJagJay's Avatar
Thanks in advance
Forgive me - but the 97 has the 5hp trans correct? If so, and it's like mine, there is a hex that is a 8mm allen on the RH side. Towards the rear of the trans on the RH side, just over the rear comer of the pan. I've dug around in there quite a bit and if it is the same 5hp with the same design,,, it shouldnt be too difficult to identify. The 8mm hex
Old May 25, 2021 | 09:03 AM
Pistnbroke's Avatar
So on your photo there are two level plugs ......these are above the filler plug ..sounds strange ...did I miss something ?
Old May 25, 2021 | 09:42 AM
motorcarman's Avatar
The filler plug IS the level plug!!!!!!!!!!!!!!!!!!!
Old May 25, 2021 | 10:47 AM
JayJagJay's Avatar
I found that photo quickly online... Disregard the two above. You won't even need to look at em... It's the larger bottom 8mm hex plug that is your,,,, *friend*. Lol
Old May 25, 2021 | 12:43 PM
Pistnbroke's Avatar
The level plug is about 2 inches above the filler plug so how can that work ..??/
Old May 25, 2021 | 12:59 PM
JayJagJay's Avatar
The plug you are looking for is the LOWER FILL plug with the arrow. I went on Google and I found a quick photo of the trans to help you see the plug you need. Honestly, I don't know WHAT the folks who originally posted it were indicating or describing with the two UPPER plugs... Forget them.
It's the LOWER plug, the FILL plug you need to be dealing with. Fill there with the engine running. Measure the temp while filling... At 40degrees Celsius, cap it when the fluid is just dribbling out the FILL hole (the lower) and BAM, you're done...
Old May 28, 2021 | 04:41 PM
MaxTorq's Avatar
gents,
my XKRFACE is a '05 with the zf6hp26....is the fill plug in the same place and look the same as the above referenced ?
thank you for any assistance,
max
Old May 28, 2021 | 05:18 PM
michaelh's Avatar
More or less:
If you're changing the pan/filter, I believe the original bolts are torx T27 (they certainly are on the 5HP). Some kits come with replacement T40 bolts. Not a bad idea given the trouble some have had with the old ones rounding.
Old Jun 2, 2021 | 02:55 PM
MaxTorq's Avatar
Originally Posted by michaelh
More or less:
thank you !
jim gilmore
May 15, 2022 06:53 PM
Fairfalcon
Jan 28, 2018 02:04 PM
2jag
Jan 22, 2013 11:21 AM
jonjay1
Sep 23, 2010 08:34 PM
brgjag
May 13, 2009 01:27 AM
