Valve cover bolt part number
Old Aug 28, 2022 | 10:38 PM
Gladiator26's Avatar
Default Valve cover bolt part number
Hello everyone
i snapped one of the valve cover bolts and I’m struggling to find the part number to purchase a replacement. Anyone who can chime in is greatly appreciated.
I need to drill out the broken bolt … not looking forward to this at all.
1999 XK8 - 4.0L - convertible
cheers
Old Aug 28, 2022 | 10:56 PM
giandanielxk8's Avatar
Originally Posted by Gladiator26
Hello everyone
cheers
Try welding a washer and a nut to the snapped bolt and using that to remove it first before you drill into the head.
Old Aug 29, 2022 | 06:25 AM
SNG Barratts has a parts break down - here is the link https://www.sngbarratt.com/English/#...r=1&layoutId=G
Old Aug 29, 2022 | 09:02 AM
motorcarman's Avatar
There are 3 different bolts that hold the cam cover to the head.(which bolt?)
Old Aug 29, 2022 | 10:22 AM
Hi, it's similar to this one.
Old Aug 29, 2022 | 11:30 AM
This was very helpful, thank you so much for the link.
Old Aug 29, 2022 | 11:33 AM
Unfortunately, the bolt snapped flush with the head, I don't think welding here is an option. I love the tip though.
Old Aug 29, 2022 | 12:32 PM
Left Hand Drill Bit!
Old Apr 8, 2023 | 01:38 PM
Hell-Cat's Avatar
A little late to this thread, but a word of caution on the valve cover bolts - the rear inner bolt is different to the other bolts and studs. It has no location nose to prevent interference with the cam sensor. Fitting a nosed standard bolt on that rear inner position may cause misfires.
See the page on Terry's Jag parts here: https://www.terrysjag.com/category/X...ket-40-V8.html
The standard bolts are #AJ810511
The standard studs are #AJ810512
The rear inner studs are #AJ810721 and requires the mounting #AJ810510
Old Apr 9, 2023 | 12:57 AM
Pistnbroke's Avatar
lots on e bay
Old Apr 10, 2023 | 04:08 AM
michaelh's Avatar
...or impale the cam sensor if you're really unlucky
Old Apr 10, 2023 | 10:35 AM
Hell-Cat's Avatar
I'm not sure that it could get that bad, but it could be hell trying to diagnose a misfire after a cam cover gasket change
I'm just finishing up a chain and tensioner update on my 01 4.0l coupe and still have my covers off. All of the bolts positions are through holes with the exception of the 2 centre bolts and the rear inner which are blind holes. The rear inner bolt hole is 5mm shallower than the centre bolts.
Trying to pull a standard nosed bolt down in that rear inner position will probably result in......snap !
vincent661983
Aug 21, 2018 12:25 PM
jagstuart
Jun 4, 2017 11:00 AM
capitaineInsano
Oct 3, 2015 02:10 PM
boostedhks
Sep 3, 2011 09:46 AM
prelude4ws
Sep 30, 2010 12:19 AM
