Higher on one side?
Old Jan 6, 2019 | 05:56 PM
rolexmike's Avatar
Default Higher on one side?
Hello fellow Jaguar owners! Happy New Year to you all.
My question is if its normal for my 2005 S-type R to be slightly higher on the left driver side of the car? I noticed when i was cleaning the wheel wells and i have a harder time cleaning the rear wheel well. I measured and compared sides and its only a tiny difference ( quarter of a inch) is this normal?
Old Jan 6, 2019 | 06:18 PM
motorcarman's Avatar
You need to determine if the vehicle needs suspension re-set or adjustment.
Here is a TSB we got for suspension diagnosis and adjustment.
You will need WDS, IDS or SDD (or similar tool).
bob
Old Jan 6, 2019 | 07:00 PM
abonano's Avatar
No air suspension on the S Types, correct?
Old Jan 6, 2019 | 07:47 PM
scottjh9's Avatar
There is a chart in the stickies for ride height and where to measure...I believe 1/4 inch is too much variance...more than likely you have worn bushings on the low side...I had the same issue and replaced all the bushings and it cured it.....the most worn out ones were the lower shock bushings...do you have CATS adaptive suspension....if so, I do not know what would happen if one was set firm and one soft...also I have read where the upper shock mounts wreak havoc when they are bad... luckily mine had been replaced by the previous owner, so I have no hands on experience there...there are some excellent suspension troubleshooting members on here...they can pinpoint cause and effect better than me
Old Jan 6, 2019 | 08:09 PM
rolexmike's Avatar
Thanks for the quick replies!
I don't think my car has air suspension, I'll try to take some good pictures of the control arm tomorrow and see if the bushing looks worn. I should be able to see it right?
Old Jan 6, 2019 | 08:21 PM
scottjh9's Avatar
Well yes and no...if you remove the wheel everything is visible....but,looks are decieving because like hoses and belts the bushings are rubber and by the time they are visually bad it is almost too late...you need to somehow use a bar or jack to move the suspension and watch for excess movement.....have the car in the air with the suspension hanging freely....i use a jackstand placed where the cutout is for the car jack to go when you change a tire ..to access the upper mounts you need to remove the trunk liner so you can inspect the top rubber ...do the measurement first and compare to spec....dont forget to measure your tires to make sure they are equal...I think you take off the wheel and measure the circumference of each...
Old Jan 6, 2019 | 10:24 PM
rolexmike's Avatar
Thanks for the information Scott, i'll attach a couple pictures with this post. Not sure if they show anything its much easier to see the difference in person. lol
Left Rear tire
Left Rear tire
Right Rear tire
Old Jan 6, 2019 | 10:36 PM
scottjh9's Avatar
The photos dontd show much...I am thinking the rear anti sway bar bushings...take a good look at those...do you hear or feel any low speed thunking or clunking at the rear...on dips...potholes...even on a driveway...I am pretty sure there are adjustments that can be done for the rear suspension...not sure what they are besides the toe in and if any affect ride height...have you had an alignment done recently
Old Jan 7, 2019 | 09:18 AM
Sorry about the AIR SUSPENSION info. I thought I was posting in the X350 section.
Old Jan 7, 2019 | 12:46 PM
rolexmike's Avatar
lol No worries
Old Jan 7, 2019 | 12:49 PM
rolexmike's Avatar
I was never good at taking pictures lol, I last had a alignment done in the late spring of last year they checked all 4-four wheels. I don't hear any clucking or strange sounds at the rear.... not even in the driveway lol.
Old Jan 7, 2019 | 03:33 PM
abonano's Avatar
Lol, no worries
Old Jan 7, 2019 | 10:23 PM
JaguarJacks's Avatar
’GOOD YEAR’ do free Alignment check and fixAflat as well
Jens boy
Nov 20, 2015 06:10 PM
zkyking
Jul 28, 2011 11:02 AM
matl
Jun 19, 2009 10:04 PM
qz39j4
Feb 19, 2009 06:25 PM
ras
Sep 24, 2007 05:08 PM
