Question about removing front hub
Old Oct 25, 2013 | 12:59 PM
phaelax's Avatar
Default Question about removing front hub
I thought replacing the front wheel hub assembly would be pretty straight forward. I removed the 4 bolts and it should come off, right?
I found this thread to see if there was something else I had to do.
https://www.jaguarforums.com/forum/s...ics-faq-39466/
I whacked away at it with a hammer but it won't budge. Am I missing something here or can this thing really be seized on that tightly?
Old Oct 25, 2013 | 01:06 PM
airanp's Avatar
I had to use a large slide hammer and a blow torch to break mine free. It was a pain in the ***. Took myself and my buddy a couple hours of beating and heating. Once it started to move though, it came out right away. Good luck.
Airan
Old Oct 25, 2013 | 01:09 PM
joycesjag's Avatar
Yep if you have the 4 bolts out whack away until it frees itself. I have read that they can get quite seized up.
Old Oct 25, 2013 | 03:53 PM
GT42R's Avatar
Had the same issue when doing my wheel bearings,
Figured it would come apart pretty easy, HELL NO! that steel hub assembly is nicely affixed to the aluminum upright...
I ended taking the upright/knuckle off the car and putting it in my hydraulic press, and pressing the hub out from the back, don't think any amount of hammering on it with it still on the car would have budged it!
Old Oct 25, 2013 | 06:09 PM
phaelax's Avatar
I'm gonna take it up to the shop tomorrow and use the torch there.
Old Oct 27, 2013 | 12:24 PM
clubairth1's Avatar
Community Influencer
Be sure and use anti-seize when you reassemble. The combo of steel and Aluminum in contact causes corrosion that locks the two pieces together.
The only thing that bond it together even better is to add some road salt!!
Old Mar 17, 2016 | 06:59 PM
tomcoo's Avatar
How about electrolytic barrier tape on the knuckle? That is what I intend to do once I get it off.
Old Mar 18, 2016 | 07:50 AM
clubairth1's Avatar
I would not use tape because the hub needs to sit flush and flat to the upright.
I wire brush everything when I get it off and then use anti-seize and only a thin film of that.
Old Mar 19, 2016 | 11:25 AM
abonano's Avatar
Anti seize works fine. I used it after replacing both front hubs. What a PITA to get out...
Old Oct 4, 2016 | 06:02 PM
tomcoo's Avatar
I got the hubs out by threading long bolts through the knuckle into the hub. built a wood frame to just fit over the hub and support the knuckle. Tapped on the bolts with a 10 lb. hammer. In time it came out. Bead blasted the knuckle clean and used anti seize for assembly of new hubs ($40.00 on Ebay).
Old Jul 11, 2018 | 11:43 AM
FarmerJohn's Avatar
I had to remove the hub to replace the lower ball joints. I knocked out of couple of wheel studs the use a few bolts to force the hub out. Worked quite well, posted a video on youtube search " Jaguar Front wheel bearing removal", hope it helps.
Old Jul 12, 2018 | 02:44 AM
Staatsof's Avatar
Ooooo sexy legs!
Old Jul 12, 2018 | 05:36 AM
You should save those, they are not available from Jaguar and having spares will ensure you never need them.
Old Jul 12, 2018 | 09:40 AM
abonano's Avatar
Very nice method. I had to swap out both front hubs on my 00 S Type. It was painful!
way2far
Aug 31, 2022 09:26 AM
tberg
Sep 7, 2015 07:32 AM
davidladewig
Sep 3, 2015 06:32 PM
innzane
Sep 2, 2015 10:08 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
