S-Type 'HOW TO' Guides
Old 08-28-2010, 02:11 PM
sjuraud's Avatar
Default S-Type 'HOW TO' Guides
Full Jaguar EPC Download, with complete install instructions. (thanks to Jim Lombardi)
Jaguar Acronymns, Abbreviations & Terms (thanks to Don B)
Jaguar Original Equipment Manufacturers (OEM) (thanks to Don B)
Introduction
Hi Everyone,
This is @sjuraud and I'm heading up the S-Type FAQ page. This page has been created to help guide members to pertinent information as quickly and easily as possible. Every effort is being made to be precise with this info. I will consider any appropriate contributions or corrections for entry in the S-Type FAQ (but can only include ones deemed by either me or in conjunction with other Admins and Moderators as needed). This section will be in a state of flux for a while until all the links and kinks get worked out. So please bear with me while the page is worked on.
If there are ANY credits that I missed for links included, please let me know. Also if I gave wrong credit to someone or the author wishes to not be linked to, let me know also.
Thanks and enjoy!
• I'm Buying a Used S-Type; What Should I Look For?• General Info & Common Trouble Spots @Jon89
Manuals & Catalogs
(Clicking on the Links Below will Download a pdf or text File)
Accessories & Consumables
Coolant
How to Remove and Replace Coolant Reservoir (4.0 MY??, Pre-2003) (tdc)
How to Remove and Replace Coolant Reservoir (aka Coolant Expansion Tank) (v6 3.0 MY03 – ???)
Oil
Filters how_to_fuel_filter_video
Windshield Fluid
Brake Fluid
Steering Fluid
Spark Plugs
Wiper Blades
Crossover Parts from the Ford Lincoln LS
(Please let me know when LS parts have been confirmed to work with the S-Type)
Electrical Distribution System
Exterior
Jacking Points Jacking points with pics and diagram
Color
Body Closures and Sealing
Trim and Linings
Bumpers
Exterior Lighting
Fittings and Sunroof
Sun / Moonroof reset
Link for Sun/Moonroof spare parts thanks to Abonano
VIN Numbers
Engine & Transmission
ENGINE
Cam Cover Corrosion
https://www.jaguarforums.com/forum/s...3/#post1617385
Oil Pan Removal by joycejag
https://www.jaguarforums.com/forum/s...eaking-141258/ Staatsof
Engine & transmission removal with pics by Tdc (2000 4.0 V8)
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-15/diy-~-s-type-how-pull-out-remove-your-4-0-engine-transmission-faq-64612/
Air and Fuel Delivery Systems
Pre-Facelift Manifold and Plenum Removal Thanks to Daxter
Vacuum Lines About PCM 171&174 Code
Battery / Starter Motor / Alternator
Engine Cooling Systems
Exhaust System and Components
IMT
Hoses
Limp Mode
Management / Emission Systems
Powertrain
Supercharger
Timing chains, Tensioners, Water pump, etc. 2000 4.0 (DIY) replacement
Tune Up
TRANSMISSION
Interior
Interior Chrome Lock Cap Removal
https://www.jaguarforums.com/forum/s...ics-faq-66296/
Headliner Removal - Thanks to cabtop
https://www.jaguarforums.com/forum/s...al-how-129199/
Headliner Replacement - Thanks to jya
https://www.jaguarforums.com/forum/s...02-how-221911/
Audio
A/C and Heating
In-Car Entertainment
Information Systems and Controls
How To Add Homelink Transmitter In Your Car
How To Fix Flickering Lights by cstich Nov 2010
Interior Door Panel & Interior Door Handles
Interior Lighting
Occupant Restraints
Parking
Phone
Seating
Security
Steering and Suspension
Trim and Linings
Vanity Mirror Cover Fix
https://www.jaguarforums.com/forum/s...ics-faq-69401/
Locking / Security Systems / Horns
Key Remote
Key_fob_facts_all_you_need_to_know
Miscellaneous
Extended Warranty
Rear View Mirror Removal by joycejag
https://www.jaguarforums.com/forum/s...ics-faq-57126/
https://www.jaguarforums.com/forum/s...pe-home-58614/ [How To Repair Water Intrusion into the Trunk ] by goblue90
https://www.jaguarforums.com/forum/s...ode-fix-61201/ by eds123
Clock Spring Removal by eds123
https://www.jaguarforums.com/forum/s...val-faq-61287/
Quiescent Current Drain by cat-as-trophy
https://www.jaguarforums.com/forum/s...-drain-123535/
Battery & Battery Charger/Tender
1. Battery 101 for S-Type Jaguars (thanks to Cat_as_trophy)
http://www.mediafire.com/view/hjfrng...ype_Jaguar.pdf
2. PowerTech PRO smart Charger (thanks to Cat_as_trophy)
http://www.mediafire.com/view/3i1943...H_(AUS&NZ).pdf
3. C-Tek Smart Charger in the UK (thanks to Timmyboy)
http://www.mediafire.com/view/anl78s...K_(UK&EUR).pdf
4. Deltran Battery Tenders in USA (thanks to Jumpin' Jag Flash)
http://www.mediafire.com/view/t81uz6...ender_(US).pdf
5. Deltran Battery Tenders in Canada (thanks to Mikey)
http://www.mediafire.com/view/42754o...nder_(CAN).pdf
Wheels & Tires
Alignment
Braking System
https://www.jaguarforums.com/forum/s...r-x350-103513/
!Special Tip When Changing Rear Brakes:
"... rear brakes on an 03+ with the electric ebrake. Basically that you HOLD the ebrake button/lever down while removing the key from the ignition. Otherwise, you'll end like me, expanding your vocabulary with new combinations of cuss words..." (Thanks Bacardi 151)
Front Hub Assembly
Standard Fitment Guide (pdf)
Modifications and Upgrades
Audio
Body
  • Paint
Engine
Custom Lighting
Electrical
  • Performance Chip
  • Removing Speed Limiter
Navigation
Software / Firmware
Video
  • Headrest DVD
Multimedia Guides & Files
Video Guides
@Gus
How To Change And Replace Spark Plugs by vance
This section below is a compilation of articles and projects completed by one of our members - Gus. He has permitted us to post these directly here, and will link to his personal autorepair web page. Its packed with DIY instructions and pictures. The information is provided by Gus for information and reference use only, and may not apply to your particular situation and circumstances. Please use discretion when using the content.
File Type: pdf
File Type: txt
File Type: pdf
The following 125 users liked this post by sjuraud:
03JagSType3.0 (03-29-2012), 1320racer (02-17-2012), 1FastCat! (10-06-2017), 2005stype (04-23-2018), 2ballcane (04-29-2014), Amadauss (02-12-2012), amicus (05-14-2016), AnOldSType (09-29-2019), aprilneo (06-18-2014), Bacardi 151 (08-15-2011), baldeagle15 (12-05-2012), Barbara Kay (08-25-2014), BBiggi (04-04-2015), beulahjag (12-22-2017), BigTimeGuy (05-15-2019), boliversmith (11-11-2012), Boog (12-06-2011), Brutal (10-17-2011), buick69 (11-12-2013), Bull27 (01-19-2011), camillo (05-24-2019), Carlg07 (01-09-2016), Catfan01 (11-03-2019), CBers (10-30-2015), CharliePar (07-18-2015), Chas King (02-28-2014), cobra29 (01-07-2014), Constantin FABRIKEZIS (06-14-2015), crebri (08-24-2012), crocodile62 (08-20-2012), daomoniker (10-23-2015), DasBeste (07-31-2011), Datsports (07-23-2016), Deeders33 (02-28-2016), domboyblue (10-27-2012), Don B (08-09-2015), Donna (11-22-2013), DougB (06-25-2012), dribler (05-25-2013), efive (07-11-2013), erdavenport (04-16-2015), FunJag (03-12-2013), gbogini1 (11-29-2013), Gimby (04-13-2015), goonergord (03-31-2014), grandhaze (09-02-2019), grant (03-28-2013), Grant Francis (10-16-2012), Greg P. (10-19-2014), Iqon (03-31-2012), jagged77 (08-25-2018), jagnewby (02-12-2013), jagstuart (05-03-2017), jaidank (01-28-2016), jeffn (05-07-2016), Jerrys Ride (12-01-2010), jimgoose (04-02-2013), jkallinen (03-18-2015), Joburger (04-17-2016), Joe Cee (12-01-2011), JoeK (06-08-2014), joycesjag (11-19-2010), Jumpin' Jag Flash (12-28-2014), kaftanka (06-21-2013), KiwiTD (07-23-2013), knockdhu (10-14-2011), kr98664 (11-25-2017), ladytinyblue (06-17-2013), Lefet (08-02-2016), LucasWA (03-16-2012), lummy (11-18-2018), malcdean (03-17-2013), Michael Star (11-20-2010), Michelle H. (01-02-2017), Mikey (07-28-2012), mkontos (10-25-2013), oldiebutagoodie (12-07-2018), ONEsicJAG (10-17-2013), orlee (10-23-2013), Panthro (09-07-2011), peterportdover (05-16-2015), PurpleHeartVet (01-11-2015), Rambunctious Jaguar (04-17-2014), rasadada (07-02-2021), Rhett (08-01-2018), Rob Puttkammer (04-13-2012), rtdbuild (05-07-2016), Sculptor923 (08-07-2012), Sean W (08-11-2015), ShiftDriftDream (05-22-2017), sjohn28 (09-06-2013), skipro152 (11-25-2015), skullbiker (01-31-2016), solidaxel (02-14-2017), Sonspit (03-03-2015), space0matic (01-25-2012), Sponge (03-04-2012), starpilot76 (12-04-2010), Steeleman (12-29-2013), Stephen (07-16-2013), SteveSheldon (04-06-2017), StoicJag (03-09-2021), STRV8 (04-29-2016), StumbleMonkey (10-26-2014), StypeRowner (11-22-2011), SunnyDay (07-31-2013), Tachycardia! (05-30-2011), tbarrow (12-30-2013), the beagle (12-08-2011), thecatofkd (03-31-2014), ThePhysicist (03-10-2012), thereheis (12-04-2012), tmurray (06-27-2012), TristanC (08-17-2011), tristarae1 (04-30-2014), turboricardo (01-10-2012), TxDevilDog76 (09-13-2014), Vicarskip (09-12-2016), Vicky Baker (11-17-2017), vlado (12-18-2018), wedgewa (08-22-2012), wnderer (07-16-2014), wpgill (06-07-2012), xstatic (10-10-2014), yo_odie (12-10-2012) and 120 others liked this post. (Show less...)
JimC64
04-16-2015 08:20 PM
JimC64
02-13-2014 07:35 PM
JimC64
40
12-22-2012 03:34 PM
JimC64
09-10-2009 12:44 PM
JimC64
05-04-2008 09:58 PM
Quick Reply: S-Type 'HOW TO' Guides
